Old 01-07-2014, 06:36 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Speaking of 16 volts.....
Originally Posted by Tom Nolan View Post
I have had problems with the XS & turbo start chargers, found the Moroso 12 & 16V the best.... they are heavy duty!
Cool! I will check on that. Need to make a change. Handy to have one that will charge both. Had no idea anybody made one.
Thanks Tom!!
Ed Wright 4156 SS/JA
Old 01-07-2014, 07:56 PM   #2
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I always have the power to the car turned off when charging the batteries to prevent those types of problems. Dyno
Old 01-07-2014, 08:19 PM   #3
Ed Wright
Ed Wright's Avatar
I turn the batt off now. Didn't for four years. Then all that carnage in one weekend. Has anybody else checked their 16 volt charger for AC voltage? When an automotive alternator does that it's because the rectifier failed. That converts AC to DC. Not sure about a charger.
MSD replaced that box, FAST fixed both ECUs. Kinda pricey weekend.
I turned the master cut off switch off while Slate's ECU & my back up MSD box was in it. Have not had another race, but will do that from now on .
Scared of that charger now.
Old 01-13-2014, 01:59 PM   #4
Pvt Parts
Pvt Parts's Avatar
I do now. Didn't for four years. Then all that carnage in one weekend. Has anybody else checked their 16 volt charger for AC voltage? When an automotive alternator does that it's because the rectifier failed. That converts AC to DC. Not sure about a charger.
Ed,
I've popped the MSD high end chip a couple of times when charging with the main switch on. Only happened when the charger to the post connection was "sparked" by someone plugging in the charger first or accidentally knocking it off while charging.
