Liked 22 Times in 22 Posts
Todd, glad to hear I ain't the only idiot that thinks this would work. I also have Chris Paget of Comp Cams, Al Parker, of Parker engines, (he builds a lot of spec sprints), and the editor of Drag Illustrated, Wyatt Halden interested, and said he would put out a huge article on it if it evolved into a class. Does anyone remember the Midwest Drag Magazine that promoted an econo class dragster\altered with flat tops, and hydraulic cams? It never got off the ground for three reasons. One, they never gave it a real chance, two, any iron head, that I think you could modify, and three, no one even knew it existed. We damn sure don't want to make the same mistakes. Anyone that wants to slam this as eventually an out of control class, needs to understand there would be NO GREY AREA! The reason their econo class never took off was the unlimited selection, and modifications allowed to the head. In that case, yes, comp guys would rule. The head is the key, and the one truly limiting factor.
don,t have one |
Liked 32 Times in 19 Posts
Randy, please explain the Cam and spring specs. Any rev kit rules?
Any Div 3 interested parties? |
We never had a cam spec in spec, which was our top class. But we had a .500 lift max in stock, .600 inch max in modified stock, and stock option. It was easy to check with a dial indicator at the valve. The Brodix spec head for Ford, Chevy, and Mopar will only except 1.55 springs, nothing larger. I think a .700 lift max at the valve will save money on valve train in spec. I found no performance difference with a cam basically in that range with a spring at 350# on the seat, and 850# over the nose, then with a spring at 285# on the seat, and 675# over the nose. So, I think it would take a lot of expense out of the valve train. Now then, if you allow unlimited lift, however, it would come into play. We were successful in turning 9,600 rpm with the lighter springs, you just had to stay on top of them. I don't care either way on rev kits. I won't use one, but I say go for it. There is less HP with one installed, so I don't think it's an issue.
don,t have one Last edited by randy wilson; 01-16-2014 at 10:06 PM. |
Spec heads would be the way to go.
Ed Wright 4156 SS/JA |
Liked 319 Times in 108 Posts
Dick,
I'm in div 3,and 46 years old, modified is what I wanted to race,I was trying to get there when IHRA still had it,but did'nt make it in time,sold that car. The spec head would put it within reach for me,alot of exotic heads are'nt that expensive by theirselves,but by the time you get everything to go with them the price goes way up,then a year or two later,there's a better setup you need to compete. I maybe able to get my hands on borrowed car,and put spec head engine together,but would take me some time. Mike Taylor 3601 |
Randy, any piston that someone makes to fit the chamber?or limited to cut costs? how about angle milling head etc?
Mike. If need be, I could loan you an engine, but only have 2 engines in the 289 c.i. and 322 c.i. Don't worry, if you hurt one, no penalty. They ain't doing me any good, and will end up being the wrong size for the class anyway. This ain't a setup, just trying to help. I'll bet I could talk Steve Thompson into one last, no break-out race if the cobalt don't sell. Guys, it's the only car we have available at this time. The deuce is up to Rob Nall's shop right now, getting work done in the engine bay, plumbing, body panel work, to get ready for the body shop. But still a long ways off. If it happens, don't plan on having it in New York, or somewhere. Central U.S.A. if possible. I think I could get Eddyville to give us a weekend, but they are now IHRA.
don,t have one |
Dick. I've gave this A LOT of thought, and I say, (now, all I'm getting ready to propose is to ease tear down) any piston, any rings, angle mill, and polishing the combustion chamber is the ONLY thing allowed other then a valve job. Any stroke, but a 1" threaded hole in the side of the pan for inspection to keep ultra trick cranks out. Any size journal. I doubt the $1,300 rings are as advantageous without the pump. Stock type oil pump, no billet. Just ideas. All we'd have to do is P&G, check pan, put a good scope in exhaust port, and down intake, and BOOM. We're basically done. But now comes the argument comp guys will fool you easily. That's where the number 1 qualifier, top speed, winner, and or runner up, record breakers have to have head OK'd by BRODIX.
don,t have one |
