Old 02-15-2014, 06:32 PM   #1
mopacltd
Liked 124 Times in 44 Posts
Default Re: VP fuel. $$$$$$ and Corrosion
I m pretty sure he is running the 110 purple Sunoco with stock eliminator compression.
mopacltd is offline   Reply With Quote
Old 02-16-2014, 02:08 PM   #2
ken robinson
Liked 224 Times in 87 Posts
I ran sunoco purple in the 350 combo never any problems alway passed fuel check
Old 02-16-2014, 06:22 PM   #3
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I do a procedure similar to Rich, with VP fuel. I have previously seen the cylinder heads, cylinder walls, valves and throttle blades rust.
Patric Fox is offline   Reply With Quote
Old 02-16-2014, 08:29 PM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Years ago a company made plastic spark plugs that were filled with desiccant, {silica gel}
Had no problems after using them, only needed to stick them in the oven when removed.
Dan Dvorak also sold header plugs filled the same way. Both took care of all the problems, all you had to do is cap the carb. Buy some silica and improvise, make your own.
Bob Pagano A/SA
Old 02-16-2014, 08:39 PM   #5
Bob Pagano
Bob Pagano's Avatar
Dan's plugs
Bob Pagano A/SA
Old 02-19-2014, 12:24 AM   #6
Kevin Panzino
Kevin Panzino's Avatar
Liked 759 Times in 139 Posts
Excellent replies and information. While I still think there may be something going on with the VP formula which is exacerbating this issue, its hard to argue against eliminating any moisture ingress.. The desiccant header collector plugs along with a carb cap makes lots of sense.
Old 02-19-2014, 08:32 AM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
also don't leave the water in the engine when its just sitting. I drain mine after every day of racing.
Mike Pearson 2485 SS
