Old 02-21-2014, 04:24 PM   #15
Ed Wright
Ed Wright's Avatar
Default Re: Calculating oil pump requirements
Originally Posted by buzzinhalfdozen View Post
I like the idea, since I've got 2 of these pumps I've wondered about cutting down the gears and putting a plate in the void. I believe it's a inch and a half pump section, which is how I believe they rate them (by body size) may be worth looking into. Maybe make it 1 inch?
I use Larry Stewart's low volume pumps. He does the same. Shortens the gears and machines a "stuffer" plate to fill the gap. Not sure how else you would do it without shortening the shaft.
Ed Wright 4156 SS/JA
