Old 04-13-2014, 08:23 PM   #15
Chad Rhodes
Default Re: TH200 issue
As stated, it won't stall up with stator free wheeling..It'll just act like a stock converter almost.
The low sprag is the weak spot alright.
You need to find out if the lo/rev clutches are on or off with your valve body.
If off ,and just the forward clutch on, I'm going with the sprag slipping..
Probably find broken springs and distortion on some kind...
It's a turbo action e shift if anyone knows the answer before I call tomorrow.
Chad Rhodes 2113 I/SA
