Old 04-17-2014, 03:47 PM   #1
1720
1720's Avatar
Liked 2 Times in 1 Post
Default Re: Front end alignment
This is what was suggested to us, for our Bracket cars:
Drag Racing Chassis Setup
(For stock type chassis)
Here is the alignment info.
Toe-in = 1/16"
Caster – 3 - 4 deg.
Camber = 0 (at ride height raised up 3”)
Driver’s weight must be in left seat.
Re: drag race alignment specs
Camber is zero but as the front end rises on launch, the camber goes out the window.
Caster - as much as you can get. About 5 degrees on both sides.
Toe would be good at zero but around 1/16" toe in is preferred.
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 04-17-2014, 08:40 PM   #2
Jim Cimarolli
Liked 166 Times in 46 Posts
Cool Re: Front end alignment
I don't think you can get that much caster, if you could the front tires would be rubbing the back of the inner fender.
Jim Cimarolli is offline   Reply With Quote
