Old 04-17-2014, 05:38 PM   #21
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Re: 7 second SS club
Bret, monitoring manifold pressure with blown engines to make the racing as close as it is not would be a nightmare. Measuring pulleys sure won't do it. Impellers and internal case modifications will alter boost and boost curves. I doubt NHRA has anybody capable of policing that, or would want to. I do a lot of tuning for ATI Procharger, and have been through their plant several times. Different engines get different impellers, they all look the same to the untrained eye, and would take measuring (and knowing how & what to measure) to know the difference. I would be amazed if some Stockers & SS cars didn't now have, or end up with, modified blowers. They would need to develop and furnish blow-off valves like F1 does. And, just like Formula 1, somebody would figure out how to screw with them. Thinking measuring pulleys like they do now is all it takes is comical.
Ed you are definetly right about the blowers in S and SS, I know a few of them in SS that are modifying the internals and gears and they are not even lasting after a few passes...........
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
