Old 04-18-2014, 07:14 AM   #1
DeasonR212
Default Re: More front end travel, or more Torsion Bar load?
Thanks George.
I have my testing mostly setup.
--Starting with C07 Radials at 20psi (can go +/- 2psi)
--Moroso DS2 at 36psi (can go +/- 4psi)
--CalTracks with 1 Turn of Preload with me in car
--Ranchos stay at 5 on rear unless I unload down track 15-20' or so, then I loosen to 4.
--Strange Fronts start Full Loose extension and 6 on dampening
--I have three bump stops I can use in the front, but have never done so
--Setup to leave at 2000rpm off FB (Can adjust -200rpm or +400rpm)
'66 Coronet - 10.07 @ 129.96/ 6.35 @ 106.72 / 1.401 60' - 3740lbs. - Street Legal
Dick Deason - R212
DeasonR212 is offline   Reply With Quote
Old 04-18-2014, 08:17 AM   #2
jmcarter
jmcarter's Avatar
What George said, you want to minimize front extension, loosening front shocks is going to slow reaction; all depending on it still hooking of course...a wider stiffer slick will help as well.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
