I had the same problems with the BG 400 pump caused by premature wear of the rotor or vane and housing inside the billet base. The pump lost 25% of the pressure in less than 150 passes. I am sending it back for rebuild the second time in two years. Thinking about going to an Aeromotive pump.
80Corvette |
Liked 510 Times in 117 Posts
A couple of years ago i bought a BG280 pump and 2 port regulator. The fuel pressure was all over the place. One minute it would be a 7 lbs and the next over 10. If i reved up the engine it would drop below 5. When it did creep up above up the carb would flood. Jegs sent me another regulator with the same results. I put back on my old Mallory regulator and the fuel pressure stays at a constant 7 psi. I now have another BG regulator but it can stay in the box as my mallory regulator works fine. The BG pump works great but the regulators are junk.
68 Chevy11 327 F/S |
Get rid of it and get a MagnaFuel. They are field servicable for $20, balanced stator (no more leaks between the motor and pump), and a much better company to deal with. I would not put a BG pump back in one of my cars if it were free...............(excpet the one I had to borrow from Little Joe at Atlanta Last year)
Chad Rhodes 2113 I/SA |
Liked 60 Times in 12 Posts
I have one, real consistent. Works great- as a wheel chock.
2894 STK |
Never had a bit of trouble with one of these....
Liked 101 Times in 27 Posts
Anybody have anything to say good about Barry Grant stuff ???????
just Barry
Liked 279 Times in 68 Posts
I've used a Barry Grant 280 for years with only one problem. I let it sit without fuel in it all winter and the seals dried out and it leaked. I had it rebuilt at a national event for $25 and it is now my backup. I use a BG 2 port regulator with no return along with the 280 pump. It works great, fuel pressure is steady and volume is good.
Greg |
rgarvey,
You will be very pleased with the Aeromotive products. In my line of work I obviously talk with racers practically every day about fuel systems, not to mention that we've tried different ones on our own cars as well. I hear good and bad comments about almost every brand out there - except Aeromotive. I switched to Aeromotive on my car a couple of years ago and my only regret is that I didn't do it sooner. They have excellent customer service as well. If you want to talk with someone at Aeromotive, call Kyle Fickler at 913-647-7300. He is one of their Stock/Super Stock experts, and he is also a racer himself. Dean Oliver www.deanoscarbs.com |
