Old 04-22-2014, 04:12 PM   #3
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: Braided brake lines
Originally Posted by nhramnl View Post
The "rule" I learned many years ago was to use as little braided brake line as possible (and therefore, as much steel line as possible). The theory (as it was explained to me) is that braided line still "expands" internally, when pressure is applied, which tends to make the brakes feel spongier.
Incorrect and misinformation unless you are using some cheap Chinese braided steel brake lines.
If you utilize steel braided brake lines that meet the DOT FMVSS-571.106 requirements, there should not be any problems.
Russel and Goodridge sell steel braided lines that meet and exceed the specification.
For additional safety, go to a hydraulic shop that can crimp the ends.
