#81 |
Liked 275 Times in 76 Posts
Thank you for the info. The floor heating is very efficient. It looks like you have heated the entire floor? So the dye in the floor also seals the concrete? It looks nice, and $900 for that large of an area is very reasonable.
Sean
#82 | |
Liked 2 Times in 2 Posts
The dye in the concrete leaves it all the same color, you chip out a piece, it is still the same color underneath. And yes the entire building is heated through the floor.
Steve Jackson Last edited by CycloneFE; 11-10-2012 at 06:40 PM. |
#83 |
Went to a lot of trouble and expense to put the heating loops in the floor and have never hooked it up. I know most of the guys who have floor heat love it. Had a small natural gas furnace so I just used that. ---Trevor
#84 | |
I am unsure about it being more efficient, but I really like the WAY it heats. Radiant heat warms objects which inturn warm others and so on. Basically the heat stays with you. Forced warm air is just that warm air movement. Air movement moves things such as dust and dirt also, and it has a blower that creates sometimes more noise. With the radiant heat in the floor the concrete holds the heat and anything that touchs it becomes warm also. I notice a marked difference in the heat in the shop when the door is opened to move a vehicle our and then the door is shut. Returning to a comfortable temp is very quick because less heat is lost. Warm air may leave the building but the concrete contiues at the same temp. The concrete must be kept at a temp that you desire because should it cool, the process to return it to a given temp becomes very costly and time consuming. Maintaing the temp is much easier. Finding a person to hook up the system was one of my biggest problem, but I did find the right guy and it works quietly and effortlessly, everything stays warm and dry. I have also noticed that in the summer with no windows I don't get any sun and it does not warm near as much and stays farily cool. I may try a dehumidifier next summer when it gets hot and it may cool it down real well. I have seen several racers mention this in the past and just continued it further myself. Thanks to classracer for that!
Steve Jackson |
#85 |
#86 |
Liked 21 Times in 6 Posts
Hey Steve your place is great looking .I have in floor heat also High efficiant gas boiler,U- Coay it on floors.A key to in floor heat is 2 inches of high dense foam under floor for insulation I heat 5600 sq ft highest bill this winter was $425 and it was a bad winter
#87 |
Liked 69 Times in 30 Posts
Nice job Steve, anymore pictures on your Garage Ken. I was turned down again for a building permit due to the neighbours.lol
#88 | |
Liked 20 Times in 12 Posts
#89 |
This Is Our Home shop On one of its cleanest days.
Tim Quintin - (driver) Cole Quintin- (Crew Chief 1970 Cuda S/G NHRA DIV 1 1970 Cuda S/ST NHRA DIV 1 |
#90 |
Liked 3 Times in 1 Post
You guys have some really great garages out there. I thought I might throw my garage into the mix. Originally got permission to build by promising my wife a parking spot (heating in the winter). It has been 15 years of updating. I am always moving and adding things.
Notice the pulley system for the one man hood removal and storage (got tied of asking for help to get the hood off). In the last couple of years I also added a small machine shop area for doing modifications. I live in the northeast so I hade to throe in a picture of my 50 year old Ariens snowblower given to me by my father-in-law. Luckily I did a valve job last year cause I have been working it hard.
Steve Cappetta 1864 STK |
