Old 05-12-2014, 09:44 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: NHRA Levied Actions Against Don Davidson
Rusty,
I feel you are correct about parts and sizes being correct by the rules.
The way things are today most good engines are built at very close tolerances. Splitting Hairs is a good way to say it.
I believe the Std Temp for measuring devices is 72 Deg F. If you carry a micrometer around in your pocket all day long it will be close to your body temp. If you measure a part around quitting time and that part is at at room temp, not you body temp, the measurement will be incorrect. The inverse applies, too. Hot or cold part and std temp measurement tool equals a bad measurement. Parts and tools grow and shrink with temp changes even though it may be a small amount they change. One should never use a "Standard" to check a micrometer if they are not both the same temps.
There is the reason for using the Standard Temp.
I think If NHRA is going to fine and suspend you for measurements being out of tolerance the parts should be measured at and by Std temps & practices. That is the same way any good shop should do measurement.
I wonder what temp that .007 out of size carb was?
In the old days I've seen guys hit a carb with dry ice fire extinguisher before turning it in for Tech. Hummm, wonder why.
At tear down I would use a chiller to bring a hot engine to Std Temp. The other use for a chiller is for performance and I think that has been covered well in the thread.
Adger Smith (Former SS)
Old 05-12-2014, 10:13 AM   #2
Billy Nees
The bottom line here has to be, why the fine?
Billy Nees 1188 STK, SS
Old 05-12-2014, 02:07 PM   #3
GUMP
Liked 2,361 Times in 558 Posts
That's what I want to know too. Is there a published "fine list" or does it get made up as things occur?
GUMP is online now   Reply With Quote
Old 05-12-2014, 03:29 PM   #4
Liked 5,142 Times in 1,963 Posts
We have a winner!
Old 05-12-2014, 10:18 AM   #5
Chad Rhodes
one thing to consider on the lift issue is that if NHRA's lifter has a different plunger height than Don's that would affect the lift one way or the other.
Chad Rhodes 2113 I/SA
Old 05-12-2014, 10:46 AM   #6
sammy pizzolato
Liked 56 Times in 13 Posts
Send a message via AIM to sammy pizzolato
I feel sorry for don i honestly do. But in his case they must have used a solid lifter to check the cam.honest mistake.on the carb he needs to talk to his carb man. And i think that one thousand for a fine for a minor lift!! That is a bit much. Now on the other hand for a big carb that is another thing!!! When are they going to start checking for the 55mm cam.half the stock elem field has them.if they are going to let them go I WANT ONE!!!!!!
sammy pizzolato is offline   Reply With Quote
Old 05-12-2014, 11:33 AM   #7
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I thought they always used a solid lifter to check.
Rich Taylor
I/SA - 321
Old 05-12-2014, 11:56 AM   #8
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: NHRA Levied Actions Against Don Davidson
Absolutely Chad! After a couple of years of being torn down almost everywhere I went with the little Caddy, Travis gave me some of the best advice I ever got. Bring your own solid lifter that matches your plunger height of the lifters in the car! It does make enough of a difference! Don't think so? Try it! Jim
