Old 06-11-2014, 05:27 PM   #1
CFMCNC
Default Re: Hardblock Question
Originally Posted by Paul Precht View Post
I fill the blocks and let them sit at least a month with both heads and main caps torqued before boring, never an issue with honing, I use Halco machine grout.
X2.Needs a month to cure correctly under stress of heads and mains torqued,also we put a 1/4 plastic tube in the water jacket to the drain plug ,after curing we pull the tube out and have draining access.Mostly use aftermarket blocks now.Bill C.
CFMCNC is offline   Reply With Quote
Old 06-11-2014, 07:19 PM   #2
BillK
Liked 30 Times in 17 Posts
I have never seen much of an issue with Hard Block. I did have a customer use one of the other brands and he had a heck of a time. Took a couple of freshen ups for that stuff to settle down
I am getting ready to fill a SB Mopar block, maybe I will do some measuring before and after and report back ?
Bill Koustenis
BillK is offline   Reply With Quote
Old 06-11-2014, 09:12 PM   #3
SSDiv6
Although Hard Blok claims the expansion rate of their product is the same as gray cast iron, when I spoke to them, they could not tell me how they based their claim.
On the other hand, Embecco 885 is a fully tested product for use by the government, with lots of supporting data and it contains cast iron in its formulation. Never had any issues with the product and the blocks have never changes in the block dimensions.
Old 06-12-2014, 07:38 PM   #4
randy wilson
Liked 22 Times in 22 Posts
I'm sure there are people who do fine filling their blocks. Just telling of my personal experience. It NEVER settled down for me in any block used. To each his own. We may have actually applied it wrong.
don,t have one
Old 06-12-2014, 10:48 PM   #5
Steve Williams
I wouldn't fill with hardblock or any aggregrate based filler. I have been using bowling ball epoxy with excellent results. Mix it to the ratio listed on the bottle and it is easier to fill and cleaner overall. Water jackets need to be clean though, no debris or coolant or oil.
Steve Williams is offline   Reply With Quote
