Old 07-03-2014, 11:10 AM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Choosing a Manifold:SBF
I need to pick a manifold to slip between a 600 cfm Holley (This Carb) and a 302 Ford in a 68 Mustang coupe. Holley and Weiland are from the same company, so I thought the Stealth would be a good match, but the Edelbrock Air Gap RPM is well reviewed, too. Both are about the same height, so fitment would be the same. It will be a 1/4 mile drag car that is street legal and must see about 40 miles of highway time to get to the track until I can afford a trailer.
Thanks.
Dale
Dale Shearon
68 Mustang 6394
Old 07-03-2014, 11:59 AM   #2
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: Choosing a Manifold:SBF
Dale…How much cam, convertor, rear end ratio? Based on your description, I'd go with the Edelbrock RPM. It has a broad RPM operating range and the respond well to carb spacers for additional plenum volume. They make excellent Torque being a dual plane. They work great out of the box. MB.
MAURICE BLENDHEIM is online now   Reply With Quote
Old 07-03-2014, 12:09 PM   #3
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
we stock sell and use a lot of the Wieand 8020 Stealth 180* high rise intakes along with most of the other popular aftrmarket SBF intakes. FYI the Edelbrock Performer is a stone makes zero power over a stock cast iron FoMoCo 4V intake
We have found it to work the best for most mild street applications It is a virtual duplicate of the old Ford muscle parts C90X intake which was the best ever street intake for a SBF and very similar to the Shelby GT-350 high rise intake and it accomodates most any 4150 or 4160 Holley and Autolite/Motorcraft 4 barrel carb. Another plus is that even with a stock air cleaner they'll still fit under most any hood. 219-861-1214 Days OR monymkrssla@aol.com anytime
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 07-03-2014, 12:29 PM   #4
FireSale
FireSale's Avatar
Comp Cams Magnum solid roller
.586 lift
288/288 duration
TCI Streetfighter trans and converter +1500 stall
Ford 9 inch with 3.89 gears comes next Thursday from Strange
Alex: Good to hear from you. Do you mean the Weiland is comparable to the aluminum manifold Shelby used for the 68 recall that finally put a good carb on a 302?
Dale
Dale Shearon
68 Mustang 6394
Old 07-03-2014, 01:05 PM   #5
ShadowLands
ShadowLands's Avatar
RPM Air Gap
ShadowLands is offline   Reply With Quote
Old 07-03-2014, 03:10 PM   #6
FireSale
FireSale's Avatar
BTW: The heads are AFR 1399.
Dale
Dale Shearon
68 Mustang 6394
Old 07-03-2014, 08:14 PM   #7
MAURICE BLENDHEIM
.586 lift
288/288 duration
Dale
Dale…RPM AirGap. Is your engine internally balanced? MB.
Old 07-03-2014, 08:56 PM   #8
FireSale
FireSale's Avatar
Yes. Eagle crank, Crower rods Keith Black dome pistons. Going to run bracket this year and switch to flat top pistons to get legal in GT for the future.
Dale
Dale Shearon
68 Mustang 6394
Old 07-04-2014, 12:16 AM   #9
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Choosing a Manifold:SBF
Edelbrock Performer and Edelbrock RPM Air-Gap are 2 different intakes. Dale, your engine sounds like much more than a mild street application,, certainly wilder than the 302s built back in the day. With your setup designed for more rpm, cam wise and converter wise, I'd go with the Air-Gap,,, but its your choice, of course. Take care.
Danny Durham
Old 07-04-2014, 01:12 AM   #10
Tand E racing
Stealth!!!
Tand E racing is offline   Reply With Quote
