Liked 239 Times in 114 Posts
I had that exact problem with my drag stars too. What I do is use a Stanley "Magic Bar" flat pry bar which fits perfectly through the spokes of the wheel, then pry between the wheel and hub, if you work it around in a star pattern, the wheel comes off no problem.
Liked 68 Times in 26 Posts
hi,I have found that tightening aluminum wheels and other parts down tight, causes the aluminum edge of hole to roll inward and grasps the shaft of the bolt tightly. therefore , it is locked!!!! I toruqe my 5/8 wheel nuts to 65 #. I've had to run a round file through the wheel holes at times to take out the lip.just food for thought.
Thanks for all the suggestions everyone. Traveling with work this week, but looks like I know what my Saturday morning will be focused around! LOL
At least it is only projected to be about 90 Saturday. Cool front for TX this time of the year! Will let you know how it goes. Ken |
Well,
Little hand torch, some WD 40, rubber mallet and dead blow, and all is good again. I did take a file and clean up the holes on wheels when done. I did get the two aspirin and a cold drink afterwards too... getting old sucks! LOL Thanks everyone. |
Liked 99 Times in 60 Posts
did you mix the aspirin with the wd40?
Larry Woodfin 471W |
Liked 905 Times in 193 Posts
I hope the "cold drink" was of the "adult" variety!
Bob Don 128 SS |
