Old 07-25-2014, 05:19 PM   #1
Signman
Liked 269 Times in 99 Posts
Default Re: Pinion angle
Originally Posted by Stewart Way View Post
Frank
On a Mopar the engine is also offset to the right as is the pinion. Is the pinion in the Camaro offset also? How far off center is the engine/pinion? Just curious.
It's years since I did that measurement when building my stocker but 5/8" to the right is a recollection. Depending on what rear housing you put in it pinion location may not be where it needs to be relative to the trans. yoke. It's worth checking if your looking for maximum or near as possible efficiency.
Old 07-25-2014, 06:45 PM   #2
Pinion is offset 1'' in a factory 12 bolt. This is how you are able to use the same length axles both sides
