Old 08-07-2014, 12:01 PM   #11
goinbroke2
Liked 404 Times in 158 Posts
Default Re: wont rev
Not to go completely in a different direction, but a personal experience.
Had a sbf that would hit 7000 in 1st (or neutral when I was getting mad) about 6000 in 2nd and 5800 in 3rd. Did all fuel and electrical diagnosing and was stumped. Was told valve springs by a well know engine builder but knew that wasn't the problem because the cam and springs were new.
Problem, the new springs were the wrong ones for the cam I had. Swapped springs and pulled to 7500 in each gear.
No load would rev clean, under load or engine accelerating slowly (in higher gears) and it would nose over and feel like the valves were floating. (hint, they were)
Just another area to look..
Old 08-07-2014, 01:42 PM   #12
dwg4859
they can test the modules? i will take it tonmight thankx
dwg4859 is offline   Reply With Quote
Old 08-07-2014, 01:49 PM   #13
Todd Hoven
Guest
Posts: n/a
When I had the problem, it broke up all over the place. It also wouldn't rev up either.
The valve springs must be good as well. I was talking about an IGN problem.
Old 08-08-2014, 05:46 AM   #14
goinbroke2
Ah, cool. I thought it was hitting a wall at 5200, didn't know it was breaking up all over.
Hopefully the module is the issue.
Good luck
Old 08-08-2014, 01:34 PM   #15
Originally Posted by dwg4859 View Post
i don't have msd i have a hei only, the fuel pressure Gage never drops below 5 psi, do i need a msd?
I don't believe your ignition system is up to par for anything except maybe Street Bracket.
I would install (minimum) a 6A , Blaster coil outside the cap and away from heat, and a new pick up coil for insurance. Eliminate the trouble sources.
You're only talking about maybe 300 bucks (American)
Old 08-08-2014, 02:40 PM   #16
Lee Valentine
Liked 319 Times in 68 Posts
What Mark said, HEI in a stocker. You,ve got to be kidding.
Lee Valentine 1661 STK
Old 08-08-2014, 11:56 PM   #17
Geerhead55
Liked 5 Times in 5 Posts
Cool Re: wont rev
X2
Danny Durham
Old 08-09-2014, 11:11 AM   #18
Liked 1,893 Times in 423 Posts
You'll never be able to count on a relatively stock HEI setup in a race car. The design was originally intended for engines that never saw the high side of 5500 RPM, and rarely ventured past 4000.
Sure, the aftermarket came up with several crutches over the years. Some work okay. But they're really intended for mild street use, or classes where the rules require stock ignition systems.
Anything that uses an HEI module, stock or aftermarket, will fail, and will never offer maximum performance.
You can "get by" using an empty HEI distributor, with only the magnetic pick up coil in it. But make absolutely certain you get a premium pick up coil for it, I have had the best results a genuine GM AC/Delco part. Also, be sure you have the correct unit for the rotation of the distributor. Do not put a pick up coil made for a clock wise rotation distributor in a distributor that rotates counter clock wise. A lot of people will tell you that it will work, but I have seen instances where it does not work well.
Old 08-09-2014, 11:35 AM   #19
Billy Nees
I have had very good results over the years using the (relatively) late model EST GM "small cap" distributors with the pick-up coil connected to an MSD 6 or 7. Just make sure that you have the correct gear for your application.
Billy Nees 1188 STK, SS
Old 08-09-2014, 02:06 PM   #20
I agree on the OEM pick up coils, but the early ones move back and forth with the vacuum advance. I have seen the wires break. Therefore any used ones can't be trusted.
At least you want to pull on the wires to see if they're ready to break inside the insulation.
