Old 08-27-2014, 12:22 PM   #1
west coast
Liked 230 Times in 75 Posts
Default Re: "Live" from Indy 2014 60th US Nationals
Found sheets across from fuel check.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 08-27-2014, 12:31 PM   #2
Brett C
Liked 1,094 Times in 230 Posts
Everyone hearing it is Jeff Colvert, car hit first net and flipped, now tangled in second net. Hearing he is ok.
Brett Candies
4192 Stock/SS
God Bless America
Old 08-27-2014, 12:59 PM   #3
Chris Hill
Liked 244 Times in 26 Posts
http://ihmusedparts.com/stock-q1-sorted/
Stock Q1 sorted by class
Chris Hill
Old 08-27-2014, 01:03 PM   #4
west coast
The car that wrecked is pitted right across the road from us. Jeff was helping unload it off the wrecker and winched into his trailer. He seems fine except the car.
Old 08-27-2014, 01:08 PM   #5
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Your turn for some reporting now! Was it brakes?
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 08-27-2014, 01:19 PM   #6
Troy Pourciau
BROWNSBURG, Ind. - 12:41 p.m. Racing is on hold at Lucas Oil Raceway Park, but not for the usual reason.
Colvert's '69 Mustang was clocked at 9.399 seconds and 141.62 mph at the finish line, but the car did not slow down as usual and went off the end of the track at a high enough speed that it went through the sand and into the multiple-net system. The momentum was so high that the car flipped upside down.
Troy "City Dog" Pourciau
Old 08-27-2014, 01:23 PM   #7
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
With the race version of manual transmissions, can you even downshift for engine braking to help slow you down?
Old 08-27-2014, 01:29 PM   #8
Chad Rhodes
I would assume no, especially with the new clutchless SS versions. I'm sure he tried
Chad Rhodes 2113 I/SA
Old 08-27-2014, 03:03 PM   #9
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
If the clutch is "light".....no
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 08-28-2014, 01:51 PM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Clutchless will only stay in high gear IF HELD IN GEAR when let off gas,if not holding in gear as soon as let off throttle trans goes to neutral, no way to put back in gear once it's out until car comes to a stop. 1st 2nd 3rd sliders/face plate are ramped on coast side to kick it out of gear,the way they work are as example when you shift to second slider engages and first gear hits ramps on coast side and disengages 1st gear, anytime when in any in gear except high gear and you let throttle or take load off trans it will kick it out of gear,and can't put it back,you always have your hand on shifter holding in gear, when trans is trying to come out of gear, the shifter will ratchet back and forth,can hold in if going slow,but faster car is moving faster shifter ratchets.
That is way LIberty's act and as far I know all clutchless do the same thing.
Hate to see Jeff's car wrecked glad he is OK ,he just went for scary ride at Bowling Green @ National open in May.
Mike Taylor 3601
Mike Taylor 3601 is online now   Reply With Quote
