It records 16 channels of data and they seem to be fairly accurate on the log except for air fuel. Took a while to get that to record right! Yes the green light does come on for the sensor so I think the sensor still works. Is the leaded fuel capable of killing the sensor after one run? Or is the two-step damaging it with cylinder cancelation and rich conditions? Thanks for your help John.
Liked 13 Times in 7 Posts
Bobby, Not sure what the answer is to your two questions. I run VP Leaded race fuel and have a 2 step as I'm sure many others do.
The Accel dealer/installer I talked to is Lee At Hesco. # is 205-251- 1472 and his E-mail is LEE@HESCO.US I have found that Accel has no tech service to speak of unless you contact one of these dealers. John |
Liked 91 Times in 51 Posts
The O2 sensor will standup to alot of runs before failing. We run VP 110.
We use the Innovate LM1 and an Innovate accessory to pull RPM from the MSD. It has a record button, and then I download to view the run. Clark |
The best wide band AFR sensor I've ever used is the NGK Powerdex AFX. It does not record by itself, but it does have an output channel that will work with any good data logger.
We ran the same O2 sensor for around two years, until it was damaged during a landing from a huge wheelstand. Someone convinced one of us to try an Innovate, that has never worked right. I have hooked a couple of good friends up with the Daytona Sensor stuff, they have been extremely happy. Daytona Sensor is what we'll be running pretty soon.
Alan Roehrich 212A G/S |
Cool, yea I'm unsure if it is the sensor not reading right or the behind the times accel software is screwing up the reading. Even the latest version of the software has lots of glitches, can't overlap graphs like I'm supposed to. One laptop the A/F ratio reads 17.99 and the other laptop it reads 9.89. So I started researching the standalone o2 systems like AEM, Innovate, and Zeitronix.
Liked 204 Times in 54 Posts
I don't want to sidetrack this post, but thought that it would be helpful to share that I just bought the two channel Accel O2 sensor kit to go along side of my Accel DFI Generation 7 for a stocker that I'm building and am not too pleased with the quality control.
I bought it from a large retailer that had it dropped shipped directly from Accel. The first time around, one O2 sensor was missing, the connection cable was missing and the housing to the computer was broken. The housing didn't break during shipping, because the broken piece wasn't in the box, and box was in perfect shape when it arrived. I called the retailer, and they took care of it and had a replacement on the way. I also called Accel to make them aware of the situation, and they seemed not to care too much about what I was telling them. The guy basically said that he wasn't going to do anything about it and had no interest in looking into their quality control. The second go round, got a new box direct from Accel again....missing an O2 sensor, but got a cable...too bad that it's the wrong one. Called the retailer, and they're taking care of it. There's no point in calling Accel, since it's clear where they stand on quality control. Where does this leave me? Let's say that I don't have a great deal of confidence in their products, and I'm strongly considering returning the O2 kit, and get my $800 back. I'm interested to see how this thread plays out. Last edited by SSGT Mustang; 08-31-2014 at 10:47 AM. |
Look at the Innovate MTX-L and a PL-1 pocket logger, or an LM2.
Liked 369 Times in 127 Posts
I run the AEM wb failsafe on my turbo Stocker.
It samples 20 times per second and I can download the file after every run. Not cheap at 300 bucks, but the failsafe feature is needed for a non-intercooled turbo engine like mine. http://aemelectronics.com/?q=product...failsafe-gauge
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 08-31-2014 at 02:31 PM. |
#9 | |
PS I noticed on my third run of the four runs I recorded the other night, the sensor gave good readings when I pulled into burnout box and even through my burnout, somewhere while rolling up to prestage it pinned at 17.98 and stayed there the rest of the run. On the other runs it was pinned at 17.98 from record start to stop and one run was 9.89 from record start to stop. Last edited by Bobby Fazio; 09-01-2014 at 09:24 AM. |
Bobby, Check the wiring. It sounds like there is a ground issue . I'm not sure if there is a specific circuit for the O2 ground, but the intermittent scenario you described would lead me in that direction.
These Accel loggers are very sensitive to proper grounding. The overall ground for the system (box) should be isolated and not stacked with any other ground wires. When I had issues with intermittent starts with my calmap unit, I was advised to run the ground all the way back to the negative on the battery. It solved my problem. These electrical gremlins are a pain to nail down. John |
