Old 09-19-2014, 10:50 AM   #1
njk53
Default Re: Good ratchet tie downs
We have used MAC's for the last 7 seasons and have not had any issue with them as far as operation or quality. I believe Summit has sales periodically on them. They are a good value in my opinion.
Nelson Kowal
Stock 345
Old 09-23-2014, 08:04 PM   #2
Greg Hill
Liked 279 Times in 68 Posts
Mac's are the best ones I've used and I've had a lot of different ones over the years. Very high quality. Made in the USA.
Greg Hill 4171 STK
Old 09-27-2014, 08:59 AM   #3
Jeff Teuton
Liked 325 Times in 50 Posts
Something we have had good luck with is we use adjustables on one end of the car only. We have them made locally with specific inside of hook to inside of hook lengths (usually between 20" to 35" depending) and then use some ratchet straps on the other end (which are also locally made). The don't get loose that seems to be a problem on a long trip with ratchets on each end. Haven't had a failure yet and easier to tie down.
Jeff Teuton 4022 STK
Old 09-27-2014, 09:15 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
I got straps rated 3330 lb. working (10k breaking) strength and associated hardware from Ratchet Straps USA, US Cargo Control, Shipper's Supplies, and Just Harris. I wanted black straps, short ratchets, and hooks with latches that mount directly to the ratchets and also have 3330 lb. working ratings, not the lighter 2000 lb. working, 6000 lb. breaking strength. I also installed D rings rated as high; the recessed ones I found were rated lighter. I wanted the working load to match the car weight for each of the four straps. In an accident, the effective car weight can easily double its actual weight.
