Old 09-21-2014, 10:16 PM   #1
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Problem cutting a light
It's a good sign if you're consistent. But is there another carb you could try? Could you have a carb "flat spot" that's not very obvious? Converter might be at least part of it, but that's still a lot to be "off".
LOCOMOTION Racing
Old 09-21-2014, 10:18 PM   #2
russellauto1
Liked 35 Times in 6 Posts
Default Re: Problem cutting a light
It's a fuel injected car. It could possibly be converter. I ordered this one from mark yacovone . I have never tried another converter in it.
russellauto1 is offline   Reply With Quote
Old 09-21-2014, 10:21 PM   #3
west coast
Liked 230 Times in 75 Posts
Whats the launch rpm?
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 09-21-2014, 10:27 PM   #4
russellauto1
Starting line rpms are 1500. I've tried 2000, but 60s slowed down and didn't seem to improve lights.
Old 09-21-2014, 11:06 PM   #5
Myron Piatek
I'm not familiar with FI cars, but I suppose it could still have a "flat spot" at the hit if the fuel curve isn't correct. Kind of like having an accelerator pump squirter that is way off on size and/or duration.
Off hand, I can't imagine a converter affecting RT's that much.
As an experiment, perhaps you can compare yourself to someone else in another car or practice tree to see how much of a variable you might be. Just trying to cover all the bases.
LOCOMOTION Racing
Old 09-21-2014, 11:39 PM   #6
Joe, How high can you foot brake it to? I can't imagine a higher starting line RPM not affecting r/t.
Being a Pure Stocker with limited duration, it may indeed go faster leaving at a low RPM.
You might end up with an eliminator setting and a different one for qualifying ..Not unheard of.
Old 09-22-2014, 12:11 AM   #7
Neil Smedley
Liked 22 Times in 7 Posts
The last thing to leave the line is the front wheels...start limiting all the wasted motion that the car goes through........too much front end travel......not enough air in slicks ect....even consider solid body bushings...
Neil Smedley is offline   Reply With Quote
Old 09-22-2014, 06:20 AM   #8
Robert Simpson
Liked 20 Times in 12 Posts
How much air in the front? With 26" it would take a large change in air pressure to affect rollout. Also, how high can you make the rear tires? Lastly, you sound consistant at the tree. Try (in testing of course), bumping in deeper on the line. Two runs only bumping once, then two runs bumping twice etc. It is worth a shot.
Robert Simpson is offline   Reply With Quote
Old 09-22-2014, 07:40 AM   #9
GUMP
You might want to try a taller rear tire. I believe the class allows a 29.5" x 9".
GUMP is online now   Reply With Quote
