Joe, How high can you foot brake it to? I can't imagine a higher starting line RPM not affecting r/t.
Being a Pure Stocker with limited duration, it may indeed go faster leaving at a low RPM. You might end up with an eliminator setting and a different one for qualifying ..Not unheard of.
Liked 22 Times in 7 Posts
The last thing to leave the line is the front wheels...start limiting all the wasted motion that the car goes through........too much front end travel......not enough air in slicks ect....even consider solid body bushings...
Liked 20 Times in 12 Posts
How much air in the front? With 26" it would take a large change in air pressure to affect rollout. Also, how high can you make the rear tires? Lastly, you sound consistant at the tree. Try (in testing of course), bumping in deeper on the line. Two runs only bumping once, then two runs bumping twice etc. It is worth a shot.
You might want to try a taller rear tire. I believe the class allows a 29.5" x 9".
