Old 10-10-2014, 02:37 PM   #6
pbp1
Liked 27 Times in 6 Posts
Default Re: GM 8.5 mini spool
It may last, but it is more prone to failure because with a mini-spool, all the load from the ring gear to the axles is transmitted only through the pin, to the bore in the cast case. With a posi unit, most of this load is transmitted through the clutches, into the inside of the case.
pbp1 is offline   Reply With Quote
