I was thinking the same thing. I always have to get out of low gear much sooner than second.
Ed Wright 4156 SS/JA |
Liked 138 Times in 51 Posts
Just to be on the safe side, if clearances and other factors allow it, try upping spring pressures a bit. It's better to have a LITTLE more than needed than a little less. Do some research on what your overall engine combo should like in springs.
Being a long stroke big block, it could work better with less rpm, as suggested.
LOCOMOTION Racing |
Liked 2,742 Times in 968 Posts
Okay, I'm good with lower rpm, but I'm thinking the intake has too much plenum and runner, agree?
Too much plenum or runner cross section won't cost power at higher RPM. My experience has been the other way around.
Liked 320 Times in 102 Posts
426ci + 525 CFM don't = 7500 rpm at the end or 6500 rpm on the shifts..
Just sayin' PS: But I could be wrong......................
If I may.....Try breathing through a straw (small carb), then try breathing through the cardboard spool out of a paper towel roll (big carb). You can only take in so much air in so much time through a small hole. The restriction doesn't allow you (or the engine) to breathe enough volume quickly enough to satisfy the needs. (High rpm or you running.)
LOCOMOTION Racing |
