#31 | |
Liked 99 Times in 49 Posts
#32 |
Liked 9 Times in 8 Posts
So what's the verdict here? Roller cam bearings? 60mm tunnel? offset lifters? Lifter dia?
lot of grey area to sort thru |
#33 |
Liked 53 Times in 16 Posts
In the spirit of "there are no stupid questions" what is the advantage of a large base circle cam in a Stocker motor? I know in a Comp motor where they RPM 9500-10000+ My 396-325 never went over 6800 and if it did lose power. Thanks Learn me something.
Will Lamprecht I/S 65 396/325 HP in progress |
#34 |
Liked 46 Times in 20 Posts
Does this mean that a ford can have roller bearings as they are the stock size and a ford part number?
#35 |
Liked 444 Times in 145 Posts
60 mm tunnel, offset lifters, lifter diameter. What are you talking about? You went back 9 months for this? Do you race Stock or Super Stock?
Bruce Noland 1788 STK |
#36 |
Liked 880 Times in 311 Posts
To quote Bobby " If it's not in the rule book it cannot be enforced. If that was the case they could make up any rule they wanted to and bounce someone just because they wanted to."
Dwight hit the nail on the head. But you guys have forgotten about "The other Rule Book" We may not be able to read it because "They Have It" It is called the " NHRA TECHNICAL POLICIES & PROCEDURES" manual. That is where the real rules that the Tech Dept follows are written. It pin points area like what is being discussed. Every Div Tech director should have one, somewhere & there should be one at every NHRA race. Between the "Rule Book" we get and their TECHNICAL POLICIES & PROCEDURES there should be no problem being consistent with rules. BTY: This is the same manual that the AHFS rules and procedures are listed in.
Adger Smith (Former SS) Last edited by Adger Smith; 12-24-2014 at 04:13 AM. Reason: SP& Add |
#37 |
#38 | |
Nascar...... .875 dia, flat tappet, 60 mm 9000+ all day long with almost 0 valvetrain breakage Most stockers have "square" lobe cams.....think about that for awhile Edit....the rulebook specifies "lift" as far as I am concerned that is all they should be checking, weather its at the valve and/or at the cam Last edited by Bill Diehl; 12-24-2014 at 09:17 AM. |
#39 |
Liked 30 Times in 17 Posts
Only 8 days left, better hope for good WEATHER.
#40 |
Liked 79 Times in 7 Posts
