Liked 325 Times in 50 Posts
We went back to back on the dyno about 3 or 4 years ago. Nothing fancy, just tubes in the collector tied to the valve covers. This was a 440 SS motor, made 6 hp no changes. Made two pulls that were identical. And we just always run them in SS.
Jeff Teuton 4022 STK |
Liked 72 Times in 27 Posts
Did anyone use a vacuum gauge to make sure you were pulling vacuum? It takes time to seal all the leaks and if it's set up right, you can pull nearly 5 inches. It's worth the effort.
Liked 20 Times in 9 Posts
Have done A-B-A testing on many types of engines, always worth 5+ hp. Connecting vacuum gauge on dyno is very important to affirm gasket sealing. Can pull 5" on a nothing fancy system. Have heard as high as 10" achievable with some work. Smoke machines very helpful, especially on vacuum pump engines to find pesky vacuum leaks. If it has vacuum leaks, it will not create a vacuum. And the obvious...ring package and ring seal always play a big part in the effectiveness.
Tom Hestness |
