Old 01-09-2015, 05:58 PM   #11
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: Connecting Rods
I have had zero issues with both Scat and Manley rods. Used several sets of Scat rods and cranks. Manley rods in the car right now.
Had to re-size one set of Eagle rods right out of the box, and had the rod bolt threads pull out of one first time it was torqued. Appeared to have been drilled with too big a bit initially. Others in that set had very shallow threads as well. Thankfully I didn't order nor pay for either set. :-)
Ed do you use the manley Pro I beam or the sportsman?
