Liked 759 Times in 139 Posts
Nick, can you say honestly, with a straight face and with self dignity, that your engine combination was factored fairly and accurately?
Liked 27 Times in 14 Posts
Kevin, my combination has a favorable hp factor. I don't think I've ever made a statement to the contrary.
Now, can you say honestly, with a straight face and self dignity, that other non-new car combinations are factored fairly and accurately? Nick |
#3 | |
Given as many years as the older cars, this engine will get factored hard as well. I just had a discussion with a man that works with a well known engine builder that builds engines for one of the fastest SS/GT 360" DP cars around, and builds some of the fast Lt1s out there right now. Same builder, same dyno, he says 70 hp difference! Same flow bench, over 60 cfm difference in the cylinder head intake ports. One full point compression. 10.5-1 for the LT1, 11.5-1 for the DP. Until late last year, they were rated 4 hp lower than the LT1. Now, finally, a whopping 9 hp higher. A DP owner (like Jeff As for the stick car deal, do you know of stick cars you can not run with? Or, just thinking about "just in case one shows up"?
Ed Wright 4156 SS/JA Last edited by Ed Wright; 01-29-2015 at 02:41 PM. |
#4 | |
I will however state, those differences are very minor compared to, say the ford 352 CJ and the Drag pack 360 and very few people were screaming over the minor discrepancies left in the 'old combos'. In fact the only one that comes to mind to me is the 235 HP 305, and even that is mere chump change compared to the rating atrocities of some of the new combinations. Lets take the two of the new combos I am familiar with: I believe your 352 has 11.25 compression, 2.08/1.6 valves, a throttle body with (4) 1.75" holes (thats 1,000 cfm for those who dont realize it) and its rated a whopping 285 HP. The drag pak is similar at 11.4 compression, 2.02/1.6 valves, and the same awesome 1,000 cfm throttle body, and rated an earth shattering 275 HP. Now I'll state again, all I ever wanted was to see these combinations properly factored, and didnt see the need for all new classes. But since for whatever reason, these combos where not ever going to be factored, they chose to make new classes. Not ideal, but something had to be done, because it was way WAY out of line. |
