#11 | |
Liked 1,943 Times in 584 Posts
Mike Pearson 2485 SS |
#12 |
Liked 13 Times in 11 Posts
I have both castings in my shop and the diff is very obvious. I believe mine is a Moroso version of the HV55 , which at the time of purchase was the heavier casting. That being said , I had a bypass spring break last year costing me a new block in the process as it threw a rod from no oil pressure and yours truly didnt have a low pressure warning light...I do now
#13 | |
#14 |
Liked 1,865 Times in 422 Posts
The base pump, the Melling M55, is a very weak casting, they will break just putting a stock Melling pick up in. This has been a problem for years, and has only gotten worse. I have a standing deal with the warehouse I buy my parts from that not even a stock rebuild gets an M55. Minimum is an M55A, which is a higher pressure pump.
The M55HV is also a different casting, although I have stopped using high volume pumps for most engines. It has seen changes over the years, it was pretty robust, then they took strength out several years ago, then, after failures and complaints, they went back to the old stronger casting. At one point, even the high pressure and high volume Melling pumps were using cheaper powdered metal gears, and the gears failed. Now they say only the stock replacement budget pumps get those gears. Supposedly, the test for those gears is to mark them with a Sharpie, if the mark disappears, they are powdered metal gears, and should not be used in performance engines. Melling has a Select line, those seem to do fairly well, they are held to tighter tolerances, use better castings, and better gears. They have several versions for small and big block Chevy applications. Melling also has a new helical gear pump for the small block Chevy, it is supposed to have less drag, a smoother pressure curve, and less pulse variation. I have not tried one yet, I may. It looks good in testing. I used the Moroso pumps for a while, as they were built to tighter tolerances than the Melling pumps, although Melling makes the base pump. Schumann was making their pumps based on the old DynaGear castings, and using the nodular iron used for rear end housings. However, the last Schumann pump I got did not look as good as the older pumps. I have not bought one since, I switched to the cast steel Clay Valley Racing pump, and that is what all race engines now get.
Alan Roehrich 212A G/S |
#15 | |
#16 |
Mike, I have not. If I were going to buy a billet pump, I'd probably buy either a Clay Valley Racing pump or a Titan.
#17 |
Mike check your PM's
#18 |
Liked 986 Times in 198 Posts
Has anyone tried a Milodon 18750 pump on their SBC.
#19 |
Liked 28 Times in 15 Posts
I thought the last Schumann I got from Jegs was a modified M55. Will look tonight, it's not in an engine yet.
#20 |
Liked 2 Times in 1 Post
We just put one in our new build this past winter. The Melling broke at the pickup support after 750 passes...no damage though.
RT - SS/X circa 1972. ![]() Talbot Racing Family |
