Old 03-30-2015, 04:33 PM   #1
Todd Hoven
Guest
Posts: n/a
Default Re: Dual sync distributor
Originally Posted by Bobby Fazio View Post
Does anyone know what rpm these go to in sequential fire using both crank and cam sensor? My car breaks up right before finish line, and in good air like Charlotte this weekend, even earlier in the run because the rpm wanted to climb. Happens right around 6500rpm, little blips here and there. Everything checks out.
Sounds like maybe a bit of valve float. IMHO
Old 03-30-2015, 05:04 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
What type of ignition, and what rev limiter chip do you have in it ?
Old 03-30-2015, 05:38 PM   #3
magnumv8
while I can't say what rpm they are good for I do know that I was told to use a crank trigger and not use the crank signal from my dual sync....
Rich Nedbal of Fastman Efi said it would not be as accurate as the crank trigger.....
D L Rambo....Stk 1300
magnumv8 is offline   Reply With Quote
Old 03-30-2015, 05:57 PM   #4
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Crane HI-6 with LX92 coil. That only has one rev limiter and that is set for the starting line launch. The EFI has a high side that I have set at 7500 that I raised to see if that had any impact.
'65 Mustang SS/L & L/SA
Old 03-30-2015, 06:56 PM   #5
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Bobby,
When in sequential mode it is not triggered by RPM. It will be active at all times.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 03-30-2015, 08:47 PM   #6
Bobby Fazio
Originally Posted by countrypuppy4865 View Post
Bobby,
Hey cooter are you talking about the rev limiter?
