Liked 3 Times in 1 Post
What tooth flexplate?
Is your starter just a mini starter, or is it a gear reduction? 1 battery or 2? 12v or 16v? Wade O |
Liked 586 Times in 162 Posts
Was the motor originally a crank hub and changed to damper? If so make sure you have the right one because there are different marks on the balancer. Had a similar problem on a street motor and used a timing tape to correct the errant marks after figured it out
