Old 05-18-2015, 10:46 AM   #1
Tim Ellis
Liked 7 Times in 6 Posts
Default Re: location of two step button in a stocker
Good points Ken. And very good idea to have tech look at it in advance . I understand what you are saying about a slow, notchy, or inconsistent action on some switches or toggles.
Tim Ellis is offline   Reply With Quote
Old 05-19-2015, 02:55 PM   #2
njk53
We put our switch on the brake pedal. I really like it just from a comfort standpoint. If you look at the photo of the button on Rich Taylor's car, ours is just about in the same spot.
Nelson Kowal
Stock 345
Old 05-20-2015, 08:34 PM   #3
D. Hake 4459
D. Hake 4459's Avatar
Liked 2 Times in 1 Post
I have an adjustable brake pressure switch plumbed into the front brake line close to the master cylinder. I have a toggle switch to energize the circuit after the burnout. I have the switch adjusted to activate about a hundred psi less than the brake pressure that I stage with. So it takes a lot of pressure to activate the two step. If you get it to come on down track you are probably sliding the tires. Just my .02
Derek Hake 4459 H/SA 69' Roadrunner
D. Hake 4459 is offline   Reply With Quote
