#1 | |
Liked 5,144 Times in 1,964 Posts
They're talking about port modifications. Screw in studs have been legal since forever. When they start DQing Chevies and early Pontiacs, then I'd worry about that rule.
Liked 61 Times in 25 Posts
The rules seem pretty cut and dry to me. They state pedestal mount must remain pedestal mount, and stud mount must remain stud mount. If it was a pressed in stud, then replacing with a screw in stud would still be legal, because it would still use the same style of rocker arm mounting.
#3 | |
Liked 70 Times in 29 Posts
Slickfoot, are you breaking the 5/15 pedestal rockers? Is that the issue?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 33 Times in 16 Posts
I believe the OP is in the midst of a build and just trying to clarify the rules.
Rich Taylor I/SA - 321 |
Liked 302 Times in 73 Posts
The reason this rule is clear as mud is because many people across the country are getting different answers from their tech guys...
it was legal in the PAST to cut off the pedestals and make it a stud mount. You had to make it work with stock parts which was very doable on the E7 head as we did it. When they changed the rule to allow the aftermarket rocker arms this became illegal. The rule clearly states that if it was pedestal it has to remain pedestal. if it was stud it has to be stud and if it was shaft it hast to be shaft.. there is no way to misinterpret the rule the way it is written.. The biggest issue is people have gotten away with having a different style rocker setup for so long no one went back and changed their setup when the rule changed. And I would venture to guess that people that "have had it this way for years... why is it illegal now?" have gotten away with it in tear down. Why is that fair to the new guy that now has to follow the new rule? Luckily it looks like I got a set of the rocker arms the OP is looking for before Ford racing stop making them. otherwise I'd be in the same ****ty place he is. BTW we have a set of heads the we had about $2000 in that are now illegal the way the rule is written.. guess what, we took them off the car cause it's ILLEGAL. I wish I had some ides for the OP as to what to do. Was actually going to be in the market for another set soon and this will make things difficult. Brad |
#6 | |
After 4 pages of comments and thoughts from various racers, we have about a 50-50 split in opinions. We can all read English but here lies the problem. The nhra gospel does not spell out an answer in English. Their ruling is covered under that verse "sole and absolute discretion" . Have you ever noticed how often that phrase is used in the rule book? East coast rules, west coast rules, this techs rules, that techs opinions........all "absolute discretion".
That being said, I was very happy to witness a tech official (thump) the side of my battery during fuel check this past weekend at Fontana. Maybe there is hope..................... |
Don't the Ford Racing rockers the OP was looking for have to be shimmed as well?
Yes and no.. You only have to shim them to get the rocker to sit on the top of the valve correctly.. The cup where the push rod rides is adjustable so if your valve is the correct length you should not need shims at all
Liked 4,379 Times in 502 Posts
I just saw a machined pedestal turned screw-in stud equipped with roller rockers and guideplates set the record last week and pass teardown. I was very happy for them, they are my friends and we helped them in the teardown but I kinda gulped when I saw the heads and got really nervous for them but it was not questioned at all. All the other aspects of the head and block were checked and passed.
