I am wanting to drop my L/SA 88' Olds Cutlass a little bit...any ideas or direction I should go? I don't want to spend a ton of money and it still has to be Stock Legal. thanks in advance for any assistance.
Liked 28 Times in 9 Posts
If the current springs are stock you will need to remove and cut half a coil , reinstall , measure and maybe repeat the process . This is the cheapest way without getting into a replacement spring such as Moroso .
Thanks Brian! Is this a major project or relatively easy? We just switched the springs out of my chevelle and it seemed really difficult. Is there someone in Central Ohio who might be able to do this for me?
We need to do the same to my sons Monte. How much do you cut on a moroso spring. What are some cheap drag shocks?
CAUTION... I have cut several pairs of Moroso springs over the years. Good springs for the price and work much better than stock. BUT they always settle a little with some use. Leave them a little longer - read sitting higher, than you want for final. 1/2 - 3/4" inch higher than what you want for final static height.
Know it is a pain in the butt to pull them out and cut a little and put back, but you can not add coils back if you cut too much. Also, never use a torch to cut. Saw or cutoff wheel. Heat from torch will kill them. Be careful and good luck. Ken Stock 412 |
#6 | |
I can cut a spring with a torch and round the cut, and dip it in water, faster than I could do it in a chop saw, where it turns blue on the and, and then I still have to smooth the cut. How is this better? Anyone? Just curious
Liked 53 Times in 16 Posts
Since no one makes any type of "trick spring" for Big Chevies like my 65 Impala I am using the lightest spring that was available which is a 6 cylinder/SBC without air conditioning. I double check to make sure by checking a MOOG catalog which is available on line and measuring. I also cut off 1.5 coils which worked well in my 68 Impala I ran.
As far as ease of installation not too sure what you swapped out of that Chevelle but putting a lighter spring with cut off coils a lot easier to install. I did not even need my motor in the car to install mine, just had someone stand on crossmember. Will Lamprecht I/SA in progress. |
