#41 |
Liked 333 Times in 180 Posts
PER NHRA BOTH BATTERIES MUST BE THE SAME!!!!!!!!!!!!!!!! --- that means the same dimensions and weight---if you run a battery in the front that is either larger/heavier than the battery in the rear OR to put it another way the battery in the rear is larger/heavier than the battery in the front -- THEY ARE NOT THE SAME--- YOU ARE ILLEGAL--YOU ARE CHEATING----- now NHRA has come out and said that if you do this ( run 2 different sized batteries)/you will be asked to leave you are thrown out /disqualified/get no points/race counts toward your total ETC. ETC. and a lot of other things---- what don't you people understand??? Its not open for discussion--- so go out in the garage and look at both batteries if you run 2 and decide for yourself if the battery in the front matches up to the battery in the rear--- if it does go back to bed--- if it does not you have 2 choices --- either get 2 batteries that are the same so you WILL BE LEGAL or keep using your current battery set up andcontinue to be ILLEGAL
#42 |
Anybody remember the gong show?
#43 |
Liked 309 Times in 88 Posts
Are we saying two fake batteries would be legal?
#44 |
YES per current NHRA guidelines however they must start the car!!!
#45 |
Liked 100 Times in 45 Posts
You mean Gene Gene the dancing machine?
Former NHRA #1945 Former IHRA #1945 T/SA |
#46 |
Or The Unknown Comic?
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
#47 |
If you have an engine in the trunk, does it have to be the same as the engine under the hood?
#48 |
Liked 68 Times in 41 Posts
that's funny
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#49 |
I have 2 in the front dont know if it is possible to have to in the back
#50 | |
Liked 138 Times in 51 Posts
LOCOMOTION Racing |
