Old 07-04-2015, 09:47 PM   #1
John H186
Default SB Ford timing cover and mechanical fuel pump setup
Small block Ford (289, 302, 351) timing cover with carbureted Carter mechanical fuel pump with cam eccentric and -6AN fittings on pump. Pump is a 100 gallon per hour street/strip pump that I ran 10.90 with and never dropped below 6 psi. Will also include a Ford Racing double roller timing chain. Setup is perfect. $50.
John, 732/910-2145.
John Hedenburg H186
John H186 is offline   Reply With Quote
