Liked 99 Times in 60 Posts
*Mark Williams is approx. $1130.00
* Strange is approx. $780.00 * About $350.00 difference between Strange and Mark Williams * I have Strange rear brakes on the Super 10 and with other buildups Strange has given good service. * The Super 10 has factory front brakes and I am looking at weight savings. Any suggestions?
Larry Woodfin 471W |
Liked 275 Times in 76 Posts
Larry,
I have Strange all the way around on my Mustang. I have tried all kinds of tricks so the front wheels will not drag due to the calipers not retracting the pistons enough. The calipers have been rebuilt, springs have been installed to push the pads away from the rotors. As soon as the brakes are applied, they start dragging again. I believe this is a common problem with Strange, so I am not sure I would install them over the MW for $350. BTW glad to hear your first outing went well! Sean
Liked 805 Times in 245 Posts
Sean,
Had the same problem, Strange brakes front and rear, the fronts would hold a small amount of residual pressure after pumping the brake pedal. You could crack the bleeders and a small amount of fluid would squirt out and then they would spin free. I swapped the brake lines front to rear and the problem switched to the rear brakes. I changed to a new duplicate size Strange master cylinder and the problem was solved. I disassembled the problem master cylinder but was never able to figure out why it was holding pressure. Jim C SS 6019 |
Liked 4 Times in 2 Posts
LAMB!!!
M.Lind D/SA 801 |
Liked 33 Times in 16 Posts
Consider Aerospace?
Rich Taylor I/SA - 321 |
Liked 780 Times in 194 Posts
Or Wildwood?
Liked 799 Times in 236 Posts
Larry, the Aerospace dual piston setup saved me 30 lbs. over the factory disc brakes on my Nova. The Wilwood stuff is pretty nice, also. -Al
"That'll never work....." |
Liked 59 Times in 13 Posts
Lamb or MW all the way. I would not even consider another brand.
I junked the Aerospace I had on my car as no matter what we did, the pedal was spongy and brake pressure was terrible. Switched to MW and immediately everything was perfect. With regard to Strange, my dad had them on a comp car he bought. He went through 3 sets of rotors and 2 sets of calipers on the car before finally giving up and going to MW. He even tried the new stuff Strange had out there and it was junk also. Installed the MW rotors and MW calipers and instantly he has brake pressure and the pads retract. No reason to save $350 on brakes. Michael |
Liked 1,938 Times in 583 Posts
I have the Aerospace on my car. They work perfect and no drag. Price is good and good customer service if you need parts or pads. I went with them because they are local to me and I have been happy with the product.
Mike Pearson 2485 SS |
Liked 204 Times in 54 Posts
There's a reason why Lamb is more expensive. They are well worth the money. No guessing.
