Liked 285 Times in 87 Posts
There is a rule that applies to what you can use.
Liked 33 Times in 16 Posts
It's kind of vague tho...
AIR CLEANERS Optional. If used, air cleaner must be OEM automotive or retain OEM configuration. Air-cleaner base may be cut or trimmed, but welding, bolting, riveting, epoxying, or any other form of fabrication is prohibited. Ram tubes, velocity stacks, or non-stocktype base plates or ducting prohibited. Cooling holes prohibited in radiator side panels, etc. Factory air cleaners and/or scoops that fit through hood must be affixed to carburetor as per OEM only.
Rich Taylor I/SA - 321 |
Liked 24 Times in 13 Posts
Rich, I saw the same thing in the "book". I guess my question would be:
when does a carb base become a velocity stack? Terry K |
Liked 110 Times in 29 Posts
Terry:
According to one of my carb customers who asked an NHRA tech man about air cleaner bases, the base cannot be higher than the top of choke housing. He said they should be able to lay a straight edge across the base and it should touch the carb. This will keep racers from adding spacers under the base therefore creating a type of velocity stack. |
#5 | |
Liked 783 Times in 195 Posts
Liked 334 Times in 181 Posts
I had some aluminum cast adapters made up for sale. They are only about 1/2-3/4 inch in thickness that will allow a 4GC carb which has a 4 7/32 in diameter opening to use a pan with a 5 1/8 inch diameter opening which is what most Holley/Quadra Jet carbs are. I have both a shallow dropped base air pan and the adapter which will fit many applications where hood clearance needs to be considered--- contact me for more pics/info---FED387
Danny, does the Speedway Motors carb base pass the "stright edge" test?
Terry K |
