Old 08-17-2015, 05:32 PM   #1
John H186
Default Royal Purple XPR oil, Pro Systems 750 carb, etc.
Royal Purple XPR 10W40 synthetic oil. Two sealed cases of 12 quarts each. 24 quarts total. $150 for all of it.
Pro Systems 750 mechanical secondaries polished carb. Great condition. $350.
10.5 inch electric fan. Works fine. $10.
Large Jegs 32A-1 fire jacket. Used in great shape. $20.
XXX-L black 32A-1 jacket. used. $20.
Manley Teflon valve seals. 11\32 valve, .530 guide. New. $10.
Comp Cams valve seals. Same as above. New. $10.
2 tire pressure gauges. 1-15 psi. Used in great shape. $10 each.
Full Bore valve lash tool. 5\32 allen. Used. $10.
Manley titanium retainers for 1.450, 1.500 springs. 8 pcs, used. $20.
Auto Meter fuel level and vacuum gauges on aluminum panel. $20.
Electric fuel pressure gauge tool. Used for checking pressure. Make offer.
Old cast iron SBC distributor. Bronze gear, MSD cap and rotor. Good for use with crank trigger. $20.
Small block Ford stuff.
VFN 5-in liftoff hood. Fits 83-86 Mustang. Has zues and pin holes. Good condition. $125. This I will not ship.
Small block Ford timing cover with Carter 6 psi mechanical fuel pump and eccentric for cam. Comes with Ford Racing double roller timing chain and aluminum pointer. $50.
Dynomax 2 1\2 inch mufflers with pipe that can bolt on to factory or any shorty Ford header. Used in good shape. $40.
All parts located in Central NJ. Local delivery no problem.
John, 732\910-2145.
I can text pics of anything you may be interested in.
John Hedenburg H186
John H186 is offline   Reply With Quote
