Liked 54 Times in 25 Posts
Liked 99 Times in 60 Posts
Fleming,
Strange [and I expect others] sells the U S Gear brand. I have installed several of that brand with good results and good service life. If you want extra insurance you can have the gear set Cryo & REM treated at a cost about equal to the gear set.
Larry Woodfin 471W |
Also, considering your application and it's performance range the out of the box gear set will most likely give acceptable service.
Liked 67 Times in 30 Posts
Dewco, they have a multi step process that works
250-300 passes no problem mid 11 second Stocker 3400 lbs
Ron Mattson 5015 STK |
