Old 10-04-2015, 01:08 AM   #21
Liked 5,153 Times in 1,967 Posts
Default Re: 1961 corvette stocker info
Mark,
If you where to run a Chevy 55-62 combination in stock eliminator, what would it be?
Ha, Money no object?
1957 Nomad, 283/ 245, 4 speed. N/Stock
Old 10-04-2015, 09:12 AM   #22
Liked 1,931 Times in 435 Posts
Originally Posted by Rory Christianson View Post
Think a standard would be fun , don't know how consistent, but would be fun
Hoping might get away with a built 10 bolt to be a little lighter
Thanks for all the input
I don't think an 8-5/8" 10 bolt would like the 4 speed, and I doubt there's enough advantage to be found to make it worth the hassle.
Old 10-04-2015, 09:38 AM   #23
Billy Nees
Liked 7,909 Times in 1,754 Posts
Methinks that if you're "hoping might get away with" anything, then maybe you shouldn't be building a Corvette!
Billy Nees 1188 STK, SS
Old 10-04-2015, 10:53 AM   #24
Rory Christianson
Liked 9 Times in 6 Posts
Me was mainly wanting input if a 10 bolt would handle it because if it would I thought there might be advantage to it being a little lighter
Thanks for the info
Rory Christianson is offline   Reply With Quote
Old 10-04-2015, 01:02 PM   #25
I don't think the later 8.5 is much lighter, if at all.
More light weight goodies are available for the 12 bolt.
By the time you piece together an 8.5 at the correct width, you won't save much.
Just buy a complete Moser deal and bolt it in.
I'm not the type to just throw money at these cars, but in this case, it makes the most sense.
Old 10-04-2015, 08:12 PM   #26
Rory Christianson
Thanks Mark
Ya the more. I Think about it sounds like that makes the most sense
Thanks for your thoughts
Old 10-05-2015, 07:58 PM   #27
Rory Christianson
What I am allowed with changes of the steering box ?
Thanks in advance for any help
Old 10-06-2015, 01:26 PM   #28
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
No matter how low of a class stocker I was building,with a stick,I would not use a rear that pro gears aren't available for.
Also 35 spline and 5/8 wheel studs do it once and be done.
Mike Taylor 3601
