#11 |
I have noticed some of you have sent me P.M's in regards to the 305 &350 block. for some reason this site is not allowing me to respond to your private message. if you can please send send it to my personnel email. gregporcello@yahoo.com
#12 |
Liked 6 Times in 5 Posts
GregP, have you let the site admins know about the PM issue? Sounds like a website glitch to me.
Last edited by Todd Boyer; 11-01-2015 at 10:15 PM. Reason: Correcting punctuation |
#13 |
#14 |
Liked 333 Times in 180 Posts
wonderful product for those that need to take advantage of it!!! however for those that can do the work themselves and do not need to take advantage of this block its still a pricey item--FED 387
#15 |
Yes it is pricey, but as I mentioned they sale the same one but for a 350 and I still have to install the sleeves. this will have performance pros and cheaper labor wise for self use or resale.
#16 |
Liked 8,021 Times in 1,526 Posts
Mr. FED , I am not sure if you are aware of this but, there are not many ...if any, good 305 production blocks in existence.GM does not manufacture any more Bow Tie small bore blocks so....that is not an option. A racer could sleeve a 307 small block Chevy ,but sleeves are not always the best way to go and sometimes come with their own problems. As stated earlier,Greg P......GOOD JOB.....from ALL the 305 guys.......M.J.
#17 |
Liked 1,856 Times in 420 Posts
Yep, you can easily run well over $1,000 putting 8 flanged sleeves in a block, before you do anything else. And I won't waste time with anything but flanged sleeves in a race engine, they solve the vast majority of sleeve problems, once installed correctly, they'll outlive the block and be trouble free.
So, go buy a block, $100, plus your time hunting it down, assuming you only have to buy one to get a good one. Hot tank and inspection, another $100. Align hone, $150. Index the lifter bores, plus bushings, $450. Square the deck, and set deck height to spec $300. Install 8 flanged sleeves (sleeves $100+ each) and bore true, $450. That aftermarket block is starting to look real nice for anything under $2200.
Alan Roehrich 212A G/S |
#18 | |
#19 | |
Liked 132 Times in 27 Posts
#20 |
Liked 89 Times in 28 Posts
FYI
Just know that the Dart block is approx 50+ lbs heavier than a stock block. |
