Old 11-08-2015, 09:14 AM   #33
GregP
Default Re: New Approved 305 Stock/Superstock Block..
Originally Posted by Rick Leininger Jr. View Post
Good job doing all the leg work for those that want or need a block like this, hope it all works out well for you.
For a from scratch 305 stocker combo, I would prefer to use a new 350 based sleeved block, which I know puts me in the minority.
Thanks Rick... But I guess I failed to mention too one of the other reason I wanted the block approved was due to I plan on moving this same combo into Superstock in a year or two and felt like that engine would more likely need the beefy block. but also as I mentioned there are many stocker engine builders already using the little M 350 and sleeving it down to a 305. this way it cuts out a lot of extra work to the block.
GregP is offline   Reply With Quote
