Old 11-27-2015, 11:45 PM   #8
nhramnl
Liked 358 Times in 83 Posts
Default Re: Bypass fuel pressure regulator systems
Thanks to everyone for their responses. Based on 1320racer's comments and photograph, I have to ask if you had a fuel pressure-based problem when you decided to put the bypass kit on? It looks from the picture that you're using -8 line into the regulator and either -6 or -8 out. Does the car use a QuadraJet, or a 4GC? I guess the key question is, were you hoping to cure a problem and the bypass didn't help (i.e. you still have the problem), were OK but put the bypass system on to guarantee you wouldn't ever have a problem, or put the bypass system on because you were assured that it would pick the car up? Thanks in advance for your answer.
