Liked 99 Times in 49 Posts
Anyone care to share thoughts on how much power one makes.??
Mine made 520-440 hds-up heads(54.8cc), gm bowtie blk, stk crank, 2-ring miller pistons, stk cam bore. Really nothing special ran .6 tenths under '64 chevelle in k. I think a good one makes around 550 hp. Larry Wilson 3058
Liked 354 Times in 120 Posts
I take it you are talking about Super Stock motors with a 4gc carb. Back in the day when my 283 520 head 4gc carb made 500 plus hp .95 under with todays indexs. 292 when you take bore and stroke = 1.71 hp per cubic inch, it would mean the 327 should make 560+ hp but there are lot of other factors into it also. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 12-07-2015 at 11:08 PM. |
Liked 66 Times in 37 Posts
Some have Qjets
72 cutlass |
Liked 719 Times in 220 Posts
There were three incarnations of a 327 250 hp engine.The first was in '62-64,it had the 520/896 heads, the.398-398 lift cam, a 4 jet or a WCFB,and a skinny plenum intake.
The third version was in '65.Same short block,cam,carb and intake,but with 461 heads. The third version was in '68.It is a large journal motor,has a .390/410 lift cam,#290 heads, and is about 9:1 compression, has an iron QJ intake with a Quadrajet.It came only in Chevelles, big Chevies,Impalas, wagons, etc,and pickup trucks.They were more common years ago, some of us still run them.They are pretty user friendly. |
I was speaking of a ss motor. I have one, never made over 505 . Never ran better than 55 under 3200 # hetler heads deno carg pg or 3 speed not a real low buck engine but not in the 28000.00 range either. Have heard they have made in the 600hp range.
Liked 319 Times in 108 Posts
How much faster is this supposed 600 hp car?
Mike Taylor 3601 |
Liked 510 Times in 117 Posts
600 HP? What actual combo is this 327/250? There's about 3 or 4 of them.
68 Chevy11 327 F/S |
Oh I think we'll find out eventually, Bob
I saw a split window 63 Vette at Pomona running one of those engines,it has gone 9's.How much power does that take?I think the 65 engine would be a riot in a 65 Chevelle 2 door post car.In Stock, you could switch from the 250 horse to the 300 horse with only a carb swap,since the 459 intake is legal on both.
