Old 12-26-2015, 11:54 AM   #26
james schaechter
Liked 1,436 Times in 299 Posts
Default Re: bracket to stocker
Originally Posted by jmoneyfoot View Post
So engine wise what are some things you can get away with? By no means are these motors stock. Lots of rpms? Perfectly balanced rotating assemblies? What are some tricks that you are willing to share?
Patience and Money. You will likely have to spend a lot of both.
Seriously, if you want to do the engine yourself, you need to find some local racers and or a machine shop that has experience with stocker engines. Making power that passes tech takes a lot of trial and error. There is not really one magic thing. Everything has to be as good as it can be. Of course, start by picking a viable combo.
If you pick a V6 combo vs a 305 for example, they want different things.
I would say to research the rule book and the classification guides. See what classes the combos fit in. Order stats from Nitro Joe and see how others in those classes run.
You probably don't know enough about it to even ask the right questions yet. The more base understanding you have the better. ( before you choose).
If there are local association races or you have local class racers near you, get to know them. Have them show you their cars. I think that will help get you started.
James Schaechter 3163 STK
