Old 01-06-2016, 09:07 AM   #1
CamCam
Liked 2 Times in 2 Posts
Default Clutch
I'm building a 67 Camaro for stock. it will be a 396/375 what clutch should I buy and the pro's and con's, thanks in advance..
CamCam is offline   Reply With Quote
Old 01-06-2016, 10:33 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Clutch
Good starter and all around good setup is Mc Cleod soft loc or Ram about same setups adjustable pressure long style pressure plate sintered iron disc,heat shields on flywheel and pressure plate.
Rob Youngblood advanced clutches,Idaho,I think where he is does alot of stock and super stock clutches.
Mike Taylor 3601
Old 01-06-2016, 10:43 AM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: Clutch
You have a PM
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 01-06-2016, 11:11 AM   #4
t.tosto
Liked 62 Times in 23 Posts
Default Re: Clutch
Welcome to the world of B/B stick shift racing. Have any details on the car? There are some very knowledgeable and helpful people on this site, have had good luck with Mcleod Soft-Loc, easy to use. Good luck, Tony Tosto 3050 B/S
t.tosto is online now   Reply With Quote
Old 01-06-2016, 12:43 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Default Re: Clutch
Brad Z has a McCleod soft lock clutch set up for sale in the classified thread. He is as good as it gets with a stick car. He might give you some tech help if you buy his stuff
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 01-07-2016, 10:08 PM   #6
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: Clutch
Call Brad he will tell you the difference between a McLeod and that Advanced stuff.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 01-08-2016, 04:23 PM   #7
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Clutch
There was a not so long a go time that a Mc Leod clutch was a much cheaper piece. But now the Mc Leod clutch costs more than an Advanced Clutch. The big difference is you get Rob Youndblood to carefully advise you every step of the way. That's what separates Advanced Clutch from all other clutch companies.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 01-08-2016, 04:40 PM   #8
Maverick
Liked 36 Times in 26 Posts
Default Re: Clutch
Do you have some numbers on how much they cost. I just got a soft loc clutch thru summit and I thought it was very reasonable. Under 2k.
Old 01-08-2016, 05:02 PM   #9
Bill Belden
Bill Belden's Avatar
Default Re: Clutch
Advancedclutches.com, is the way to go
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 01-08-2016, 05:16 PM   #10
Maverick
Default Re: Clutch
Just looked at the advanced site, and the price looks the same at what I got thru summit. I will probably check them out soon.
