#11 |
Liked 482 Times in 159 Posts
Agreed, any tech articles on stocker engine builds are fascinating. Although some of the methods or parts may be outdated, anyone that can post links to old stocker engine articles ... thanks in advance. I recall a great one on Bobby DeArmonds 427 after he ran a "9".
#12 |
Liked 101 Times in 34 Posts
Dave boertman's article, I believe, showed sealed power's head land top ring (basically a 1/8 inch wide dykes type ring at the top of piston). Ron.
#13 |
Liked 56 Times in 27 Posts
Dwight,
You are dead on with your response about the early days, most people did most of their own work ... They learned from their mistakes & became better racers for it ... Today, it's all about the $$$$ & the spread between the have's & have-nots is growing wider !!! So, your point about the articles is a great one !!! You should never stop trying & learning ...
Dave Ribeiro 1033 STK |
#14 | |
Liked 7,785 Times in 1,744 Posts
#15 |
Liked 880 Times in 311 Posts
I might add that I think "The Net" has caused some of the "Old School" tried and true ways of doing things be discounted by the younger generation. The Gen X,Y and now the Millennials are all so computer literate that is where they go for information. The "Net" has created so many keyboard guru's that have little or no experience with actually squeezing the most out of parts and combinations that those methods are lost. I just think there has been a loss of some information in the information age. The X,Y and Millennials can get information, but they are only getting what is quick and easy. The Net has caused the "Hands On" experience that was handed down in Apprenticeship type situations to go by the wayside.
As an Old Fart that has plenty of both good and bad experience that is just my .02 for free, on "The Net"
Adger Smith (Former SS) Last edited by Adger Smith; 01-17-2016 at 12:34 PM. Reason: sp |
#16 |
Liked 719 Times in 220 Posts
It seems amazing that 30 years ago, what we had to run to remain legal in Stock Eliminator even worked at all. Those were the days when a run just under the index was something to be proud of. The constant evolution of the sport has been constant,relentless,and outstanding. One of the sure things, there are no more car magazine articles that feature this stuff like there once were. There was a tremendous amount of learning to be had from those years. I got belittled once that"Reimer doesn't know anything but what he reads in car mags". I thought that was a complement. Obviously, that detractor never read many magazines, or he'd know something too.
The evolution of Stock Eliminator into what it is now isn't just motors, but tires,wheels, chassis tweaking,converters,transes, all in all, the cars just aren't the same.I don't know how a new racer could ever do this if it wasn't for the vast herd of experienced racers out there that have a vast pool of useful knowledge. Believe us, it doesn't come easy. |
#17 |
Liked 133 Times in 76 Posts
I remember reading that Chevrolet used cleanser as a field fix for seating rings on the early V-8's.
As far as the just pay someone to do it and the lack of tech articles it's the same in bracket racing. Few if any do the work to their cars. I'm constantly amazed at the people that race that do no work at all on their cars. |
#18 |
I still have my stuff for that. When I was running my old C/SM car in the mid '70s I was WD for Manley. Their Pistons were stocked with no top ring groove. 2nd was .043", oil ring was 3/16". I bought them that way.
My ring fixture is/was 4.030" on one end, 3 7/8" +.060". (Had a 292" & 306" engine.) Had a sharp machinist friend that made a fixture to hold the Pistons, and a tool to cut them. After lapping both sides flat while compressed I lapped them to .041". We used .0005" vertical, and .001" back clearance, with .040" vertical gas ports. Had a piece of 3/8" steel plate parralell ground to lap them on, laying in my parts washer, with the pump flooding the paper. I had one end opened up to 4.070" for my present engine. Not as easy to see on these shiney .028" Total Seal rings as the black .043" rings, but they appear to be flat. Layout ink also comes off first swipe on 400 wet or dry paper.
Ed Wright 4156 SS/JA |
#19 |
Liked 10,779 Times in 2,240 Posts
Good article on Scott's B/SA car, man is that thing fast. Does anyone know what rod bearing to order that is for a crank pin of 2.200'' with a Pontiac rod housing bore of 2.375'' ? I got a neighbor that would love to save his OEM crank.
#20 |
Liked 706 Times in 283 Posts
So this should still be done if ring manufacture doesn't?
