Old 02-04-2016, 10:06 AM   #17
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Re: Questions on lifter bore correction
Thanks guys. Looking at some dated drawings, w/o dimensions no less, The BBM lifter looks to be 90 degrees to the deck, so at least for this block using the crank and cam centerline to swing the angle, then line up with cam centerline should work. I do dimensional inspection work for a living, so I enjoy understanding how this stuff is done.
Originally Posted by Allen Sherman View Post
Sorry I'm slow responding, I don't usually get on here while I'm at the shop, but Dwight answered the question already, we have factory blueprint locations programmed into the CNC, and if needed we just make program changes if an angle or location change is required...
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
