Liked 28 Times in 15 Posts
Can't help on the 8 1/4 but the DANA 44 is supposedly as efficient as the Dana 60. Moser makes aftermarket axles, spools and gears are available. 4 89 5.13 5.38 5.89 that I know of. I have a Summ ers Bros spool available.
Liked 242 Times in 81 Posts
Hey Bill, we have a brand new 8 1/4 Strange spool and 5.38 gears. Would let them go cheap.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Bill: The 8 1/4 lasted several years in our 11/12 Second stockers in the
70s. They are lighter and a bit faster. Gear supplies dried up in the 80's with the deepest gear available 4.50. and no 4.80 to be found anywhere. The slant 6 should be fine unless you re using transbrake and 7 inch convertor.
#4 | |
http://www.summitracing.com/parts/spz-36268/overview/
Rick Blake 2395 SG, SC, SP |
Last time I ran one was early 1980's. Only gears then were from Mopar
Perf. that I could find. My 1980 Dodge Mirada O/SA is still running a 8 1/4 to this day in stock competitively on East Coast. I do not know of anyone else in stock although there may be others. The Mirida runs mid 12s at 3620 lbs. and has the same ring and pinion for at least 30 years and three owners. Larry Shephard told me back when these cars were new when Chrysler changed from 8 3/4 to 8 1/4....they saved about a dollar a unit!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 02-18-2016 at 01:23 AM. |
Randy's Ring & Pinion. the new Yokon case is very good
Liked 805 Times in 341 Posts
I am one of many that has swapped a 8 3/4 for a Dana, not done anything else and not slowed down a bit.
Bill |
